| Maybe this is completely normal, but I never really had this problem with my NA engine (swapped to TT). I notice under hard acceleration, when the boost begins to build to 8psi and up in 2nd gear, my car will begin to pull to the side for a second, and then I sort of let off the throttle and it straightens out. Now, I know this may seem stupid since it is quite possible that one tire is slipping a bit more than the other. However, I just wanted to check how common this was for folks? I installed some decent coilovers that dropped the car, but I measured the setup to make sure they were relatively equal on both sides. I also have ST swaybars on the front and back. I absolutely know that I still need an alignment on all 4 corners. Just wanted to know everyone's thoughts....
